Old 09-08-2009, 01:20 PM   #13 (permalink)
orange4boy
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
For your brakes, You could add a larger vacuum tank. You can easily make this from a plastic plumbing pipe with caps glued on each end. Thread a small barbed hose fitting into it and attach it to the vacuum line with a "T" fitting between the check valve and the brake canister.
Mine is about 6 litres and lets me safely brake about 8 times from 18 inches of mercury.
It makes EOC much safer.
