I wonder if there is a simple way to force a higher gear, i.e. remove kickdown linkage, put check valve in transmission vacuum line, put weaker/stronger spring somewhere in valve body, ???. Then just use the selector lever to choose the gear (and put the lockup toggle switch on the selecter lever)
