Old 09-09-2009, 10:09 PM   #128 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Originally Posted by sprale View Post
I've had a few older motorbikes over the years, though never pushed to get high mpg's. My first was a 1982 Honda C70 Passport, aftermarket carb and a few other mods. I think I hit about 120mpg once, but it's not a big bike by any stretch.
I had a 1984 Toyota Tercel 4WD wagon that would hit as high as 42mpg in Missouri winters in the mid-90's, but that's as good as it gets for my cages.
My current is a 2007 Ninja 250 with about 27k miles. I've put a tall custom Lexan windscreen on for comfort, a rack with a top case and saddlebags. I've swapped the gears for a 15/41 set from JTSprockets, the tires for Kenda's K657 130/90-16 rear and K671 100/90-16 front. Lots of other little farkles, but it's mostly set up for comfortable commuting. Even so, I hit 81mpg on a fairly straight and somewhat hilly stretch of Hwy 29 North of Austin. I was running about 65mph. Don't remember the temp, but it was spring. I need to strip it down and see what I can max it out at someday...
Nice bike!!!! Good to see a fellow ninja 250 rider on here.
You have pretty much the same bike setup as me, I'm just a little lower on gearing. What shield do you have? One of mikes shields?
Have you messed with the jetting at all?
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
