Thread: Aero'd 07 Aveo
Old 09-10-2009, 12:56 AM   #15 (permalink)
Wonderboy
Wonderboy's Avatar
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 46.19 mpg (US)
That's a really good idea Darin... I really have to put a rubber gasket around my mounts (and my friends'). Even though none of the parts I used will ever rust, I still have to be concerned about the well eventually rusting. Any wise ideas about what I can do to the back side of the metal screw-punctured areas? Maybe some marine caulk?
I'd like to know how you attached the wheel skirts.
I explained it in harrowing detail a couple posts ago, but a picture is worth a thousand words I guess. Here's a photo from when I did it to my civic. That aluminum band I'm holding goes right where it looks like it should go. The holes in each side of it are threaded. To put the skirt on, puncture the coroplast skirt directly above where those threaded holes are, and screw it right in. Very simple.
I would if you were closer
HAH! pay the airfare and I'll be there, coroplast in hand.
