Old 09-10-2009, 05:46 AM   #12 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
Originally Posted by vtec-e View Post
Someone here mentioned using a central locking motor. It would only be fully open or fully closed so you wouldn't have the level of control to maintain a certain temp. But if you are just using it to improve warm up times then it should work very well. Plus, it's made for use in a car with its mounting points and also designed to work with a cars voltage.
Any idea as to the current that a central lock motor uses? Can I run it through a 20A switch, or should I use a relay?
Piwoslaw's Peugeot 307sw modding thread
