Thank You
Good suggestions all.
Thanx
BoxChains link led me to the Archimedes Method which I believe is what I vaguely remember from some classroom in the seventies.
TomO, that is the method I was planning on using. Trial and error.
Measure, mark, rinse, repeat.
LostCause if that is true then that will work.
I am trying to make three holes around the perimeter of the new wheel covers.
I want them as close to perfect as possible.
So.
I can transfer wheel to wheel without always having to line up the holes.
Well off to the races.
Thanx Again,
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
