Originally Posted by MisterJeeves
Hi there,
I just received and installed the Scangauge on a 04 Ford Focus ZX3 2.3L, manual transmission.
I have a question for anyone with experience in the matter... Shouldn't the SGII read 9999 (infinite) MPG instantaneous when the momentum of the vehicle is propelling the car and the fuel injectors are shut off? I get better FE when coasting in neutral and it certainly never reads infinite.
Any ideas?!
Thanks all
-Brendan
Unless your focus is a hybrid, then you won't see 9999 MPG with the engine running.
The only way you are going to get 9999 MPG on the
SG on a non-hybrid is if you shut off the engine and EOC. Or if you have a car that has fuel cutoff while in gear (DFCO?), then you can coast
in gear down hills and see 9999 after a few seconds. Good luck, and welcome to Ecomodder!
