Old 09-11-2009, 11:08 PM   #24 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Originally Posted by some_other_dave View Post
That is still a low throttle setting to my way of thinking. I really don't think I understand what you are saying...
What happens is the 25-30 hp point is on a steep part of the power required curve. Any slight rise or additional drag requires the engine to run up that curve into higher consumption and even more inefficient power settings:
The areas of peak engine efficiency are marked by the small, red dots. You'll notice the 25-30 hp curve fall right under the last of them. Any higher power demands push the engine into inefficient, lower BSFC regions.
So it is a combination of two effects:
  • steep power slope - so any local variance in power demand will rapidly go into much higher power regions
  • upper limit of high efficiency - anything over 30 hp is going to have lower BSFC than the 25-30 hp region.
I've thought about making a cruise control device that limits the peak HP setting, just using the ICE rpm of say 2,600 rpm AND a maximum speed. The car would slow down going up a hill but it would stay in a fuel efficient mode. But it in an actual design, I would allow excursions up to 3,400 rpm to handle hills. If any more is needed, the accelerator would be used.
Bob Wilson
Local record
