Sounds like it could be a bad data value in the saved data portion. Fuel use is an additive value, each cycle, more fuel use is added. Since fuel consumption is not calculated, nothing is added, so it should stay the same. Perhaps the bad data is a result of power being removed during the save routine? Is it just in TRIP fuel, and never in TANK or OUTING? Is it always .03 Gal when it shows up?
Is there a set of steps where this is reproducable all the time?
