"large 2F car A/V capacitor" means??
Actually a friend suggested:
1000µF, 160 mOhm series resistance, and 21 mm diam x 38 mm. in size, priced just under $10 each plus shipping.
To be put across the 12V+ and ground wires at the OBDII connector. I took one look under there and decided I didn't want to try performing surgery in that tight area which also leads directly back to the computer. So I built the relay circuits which I was confident I could do without causing trouble, and get improved lighting and horn output also.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
