Old 09-13-2009, 01:38 AM   #20 (permalink)
orange4boy
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Hello,
I've got the same issues. I'm using a spiffie kit in a 93 Toyota Previa. V.75
I already took mine apart and resoldered everything. It gets worse and worse. Crashes sooner and sooner in the same way described by Tygertec.
I even have mine hooked up to a 3.5 AH battery separate of the car.
One thing I noticed is that my injectors have 12V on each wire with the ignition on. car not running.
Recently the gph started to run like it was attache to the vss. Adding to itself.
Could this be a connection to ecu wires issue? I didn't solder the VSS. although I did just solder the inj.
