Are there any issues with using the earlier versions of arduino?
Can you just flash the chip with the older versions of the code like .75
If you plug the USB into your PC, the PC recognizes it as a serial port, and you should see economy, speed, etc. being spit out.
Where / on which program would I see the data on a mac?
