Old 09-16-2009, 12:24 PM   #3 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
FYI the latest source for the prebuilt is at: http://opengauge.googlecode.com/svn/...no/mpguino.cpp
Here are the default values from there:
PHP Code:
unsigned long  parms[]={55ul,8208ul,500000000ul,3ul,420000000ul,10300ul,500ul,2400ul,0ul,2ul,0ul};//default values
char *  parmLabels[]={"Contrast","VSS Pulses/Mile""MicroSec/Gallon","Pulses/2 revs","Timout(microSec)","Tank Gal * 1000","Injector DelayuS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms","InjTrg 0-Dn 1-Up"};
Let me know if that makes sense or if it needs cleanup.
