I had a similar question related to air dam design, so I'll add it to this thread. What is the goal on the height of the air dam? Should it just extend low enough to be level with the suspension components? Or should it be a set height above the ground?
With the original poster's Topaz, I assume it's close either way. I want to add one to my 2wd 2003 Silverado pickup, and I'm unsure what a good starting point would be for the air dam height.
