Old 09-16-2009, 04:16 PM   #5 (permalink)
micondie
micondie's Avatar
moby van - '03 Caravan SE
90 day: 19.74 mpg (US)
The purpose of an air dam is to direct the air flow toward the smoother outer body surfaces instead of the aerodynamic nightmare underneath. If you plan to put the dam just below the bumper then you are limited by driveway clearances. If you put it closer to the wheels then you can have it much lower.
Bottom line: lower is better!
