Well not really. The whole assembly is "locked together" at engagement speeds plus; no matter what you do with the throttle it all needs to slow down and/or slip enough to allow weighted clutch pads to disengage. That's how my go carts and things worked anyway.
On this set-up the two chains and jackshaft always turn whenever the wheel turns so whether the clutch is disengaged or not there is a fair amount of driveline resistence to coasting.
