Old 09-17-2009, 09:00 AM   #19 (permalink)
Backtobasics
Dart Lite - '76 Dart Dart Lite
90 day: 18.34 mpg (US)
The Teal Truck - '97 Ram 1500 Club Cab / Short Bed / 2wd
90 day: 14.74 mpg (US)
The H Bomb - '93 Accord LX
90 day: 32.21 mpg (US)
Originally Posted by ceej View Post
Interesting.
Are you sure the Holley is the original Dart Light unit? Sounds like your timing chain has had it. 20 mpg with that car is pretty low.
Check the list number to see if the carburetor is the correct one. If there is a Holley 1940 or Carter BBS on there, it's not right.
SlantSixDan up on slantsix.org had some special Holley 1920's at one time, NOS. I bought one for the build on my wife's '63 Dart GT. I have the correct Aluminum 1 bbl intake. One that isn't cracked in the plenum floor. (A rarity.) I've got a Feather Duster 2-1/4" head pipe that came off when I installed Dual Dutra Duals into twin 2-1/4" head pipes on my drag car.
Also check your distributor and vacuum advance can to make sure they are the correct ones. The vacuum amplifier that runs the EGR may have problems. If it isn't there, you sure don't want to run the Feather/Lite distributor curve. You'll jack the Cylinder head temperatures through the roof with 52 degrees total timing and no EGR.
Got some pics of the engine compartment? Unmolested Feather Dusters and Dart lite's are cool! And Rare!
CJ
I recognize the screen name.
I futz around over at .org from time to time.
20 isn't great for sure. I had not considered timing chain. Original motor has fair amount of blow by so I know it is aged.
Carb is a 1945 if memory serves. I rebuilt it when I first got the car. The bolts holding lid to main body AND bolts holding base to main body were stripped. I tapped them out and rebuilt. I sorely need to find or build an accellerator pump rod, it has no acc pump shot right now.
I might need some help with the distributor and EGR curve stuff.
I will get some engine shots.
1976 Dart Lite /6 with 3 speed manual
