Some progress again.
2x register lights swapped to leds.
New cold air intake pipe done, and started the evo II front bumber. New headligth swap is a no go, because they are too big
. however I will put the DRL:s in some place anyway.
I also recalibrated my
scangauge and changed also the units to Miles, because the difference is so litlle when going below 3 litres that it is hard to notice the differences. I got average consumption of 96 MPG @ avg speed 51 MPH behind A truck for 40 miles distance. Long dowhill sections the number were at 101 MPG.
I would also recommend all european drivers to start using MPG category if your consumption is below 4 litres/100km. This way you see more accurate results
