Old 09-17-2009, 07:21 PM   #894 (permalink)
nickdigger
Addition to above processInjOpen/Closed procedures: Discard Too-Long Pulses.
Code:
#define injEdgeIdx 10          //v0.82
#define injectorMaxTimeIdx 11  //discard any pulses longer than this value
#define parmsLength (sizeof(parms)/sizeof(unsigned long)) //array size
char *  parmLabels[]={
"Contrast","VSS Pulses/Mile", "MicroSec/Gallon", "Pulses/2 revs","Timeout MicroSec",
"Tank Gal * 1000", "InjectorDelay uS","Weight (lbs)","Scratchpad(odo?)","VSS Delay ms",
"InjTrg 0=Dn 1=Up", "Max Inj Pulse us" };
unsigned volatile long maxInjOn=0;
// use for debugging, display it on a Custom screen.  See what kind of pulse length we can expect during normal driving.  Then, set injectorMaxTimeIdx accordingly.
void processInjClosed (void)      //v0.82
  tmpInstInjOn = elapsedMicroseconds(injHiStart);
  if (tmpInstInjOn > parms[injectorMaxTimeIdx] || tmpInstInjOn < injectorSettleTime)
    tmpInstInjOn = 0;   // now weed out too-big & too-small pulses
  else  tmpInstInjOn -= injectorSettleTime;
  if (tmpInstInjOn > maxInjOn)  maxInjOn = tmpInstInjOn;   //debugging info, to find max injector length
void processInjClosed (void)      //v0.75
  if (tmpInstInjOn > parms[injectorMaxTimeIdx] || tmpInstInjOn < parms[injectorSettleTimeIdx])
  else  tmpInstInjOn -= parms[injectorSettleTimeIdx];
