Old 03-06-2008, 02:01 AM   #6 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
A/F Ratio
Having installed an A/F ratio meter (with similar LEDs), I can say that's it nearly worthless.
This was on an '03 Evo -- the LEDs would be consistent only in open loop: cold start or full-throttle. The closest use was A/F at full-throttle, full-boost (in those driving situations, a quick glance) to see if a lean situation was apparent (rare if ever).
Otherwise, the meter bounced back and forth under normal operation.
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
