Old 09-19-2009, 01:18 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
The bike thing works, just kinda noisy (magnetic reed switch).
junkyard/autozone hall sensor (vss or crank position sensors), near a magnet strapped on the transmission output hub (with something on the opposite side for balance) would make the basis for a solid vss signal, though I wouldn't run it constantly even with the key removed.
A a kill switch is the typical way of dealing with issues relating to turning the key back. If the kill switch is a well positioned microswitch mounted on the stick shift then it becomes a very "natural" part of your driving style.
