Old 09-19-2009, 01:26 PM   #53 (permalink)
jamesqf
Originally Posted by MadisonMPG View Post
Diesel's weight is outweighed by it's torque and quality.
Don't know enough to comment on that, but it's beside the point. What we were discussing was replacing an existing IC engine with batteries. Now if you have a car with two IC engine options that give the same power & performance, the diesel will almost certainly weigh as much, probably more, than the equivalent gasoline one, no?
So if Tesla can replace the Lotus gasoline engine with a battery pack that gives X range, etc, then it seems reasonable to suppose that VW could replace the diesel in their 1L car with batteries giving similar range, no?
