It all depends on how bad you want big results.
You piddle around, you get piddle-around results. To get big results, go big.
You can get 3.00:1 gears for a Maverick. That might help.
Want big results? Go with a diesel and a five or six-speed manual transmission. A M-B OM617 will fit and the turbo versions are indestructible at the 120-150 HP level. You might get a custom bellhousing for a VW TDI.
Diesel + stick easily puts you in the mid-30s.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
