Old 09-21-2009, 08:50 AM   #28 (permalink)
Backtobasics
Dart Lite - '76 Dart Dart Lite
90 day: 18.34 mpg (US)
The Teal Truck - '97 Ram 1500 Club Cab / Short Bed / 2wd
90 day: 14.74 mpg (US)
The H Bomb - '93 Accord LX
90 day: 32.21 mpg (US)
Originally Posted by Superturnier View Post
I think changing the carburettor model from 1 barrel to 2 barrels would give some improvement in mpg.
Primary venturi could be small size as it it used mainly for cruising
Secondary venturi could be much bigger giving you power for the occasional accelerations.
My accelerator pump is not working, and it's not needed, because I have quite small primary venturi on my carburetor.
Smaller venturi atomizes fuel better on lower rpm.
I like the idea, but I am not aware of a commonly available carburetor in 2 barrel configuration that is spread bore, or said another way, small primary and large secondary. 4 barrel carbs can be had this way, and I have one waiting for later stages, that is configured this way. Do you know of a staggered 2 bbl carb?
1976 Dart Lite /6 with 3 speed manual
