Old 09-21-2009, 09:34 AM   #168 (permalink)
adamj12b
EVVette - '71 Corvette Coupe
The servo packs I have are all Yaskawa CACR-PR series. Im using them for the milling machine that I am building. They were salvaged from a friends machines that he was scraping. I dont really want to take the rest of them apart, as they all work fine. This one was repaired once, then it broke again, and put into storage, So I didnt feel bad taking it apart.
The others get really small real quick. Most of them are only rated up to 1 HP.
Plus, going my planed route with 45 TS 180's and a warp 11 will be under factory weight, but if I have to double the batteries, it will push it over. I would have to go down to 100Ah cells as well as I could not afford 45 180's.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
