Old 09-21-2009, 03:06 PM   #116 (permalink)
The Atomic Ass
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Originally Posted by HUM727 View Post
not sure if someone replied yet but the reason ur bike was pinging is cause that gas should not be in your bike, all bikes that i know of, and my sister has that bike, run on premium gas... it may cost 20 cents more butto use 87 u loose fuel economy and performance as well as risk damaging the engine.. figured i share some info on the small amount i know. u might read somewhere that it can take 87 or should.. from my experience that is nothing but bad news
if it wasn't the gas .. the only other reason it would be pinging is sometimes the engine is cold
premium is also much cleaner and on a carburated bike.. that means taking care of the bike much less, cleaning the jets less, and make the spark plugs and valves last just that little bit longer
Premium fuel is not universally cleaner, certain brands add the same detergents to all the grades they sell, so there's no difference in how "clean" the fuels are.
And the Ninja 250 is designed to run on 87. That being said, I've never driven my Ninja for economy, though that is going to change here soon, as the Burgman has a lot of issues that are going to require grounding to correct. I don't doubt that the engine will ping at WOT at low revs, and IIRC, Bryan is tuned a little on the lean side, which makes it easier to ping regardless of the grade.
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
