There's never been a manual. It'll be a tiptronic, which is a manual three speed 'box with a two speed overdrive and all electrically operated. The driver just uses the gearstick in the centre console to select drive/neutral/reverse and tap forwards to change up, pull back to change down. Whilst there is a clutch, it's operated by the ECU and there's no pedal. There's an optional extra to have gear change paddles on the back of the steering wheel too.
