Old 09-23-2009, 01:30 PM   #63 (permalink)
TomO
That VX guy!
TomO's Avatar
Thrifty McGassaver - '94 Civc VX
90 day: 41.98 mpg (US)
2010 Elantra - '010 Elantra GLS
90 day: 27.23 mpg (US)
The Tank - '06 Touring DE
90 day: 66.87 mpg (US)
Send a message via AIM to TomO Send a message via Yahoo to TomO Send a message via Skype™ to TomO
Ok, I can't leave well enough alone....cause I don't think it's well enough, lol.
I found someone selling conveyor belt rubber on eBay HERE and I will be purchasing a 4" wide 1/8" thick roll to make a rubber version of the FiberEdge Lip for use during winter. Unfortunately it's a 50' long roll. I guess I'll have to make a few lips for some of my friends
I believe the duromter rating on the material is sufficient to flex well and still be able to retain its shape...can anyone confirm this that knows more about durometer ratings?
The brackets will be recycled from the FiberEdge Lip but cut down so there is only one bolt holding on the rubber per bracket. This will allow the Lip to still hang down nice and low, but will also allow the rubber to move out of the way when it hits something.
I can't wait until payday now, lol.
I've always wanted/was inspired by Rubber Racing Lip.com but cost was prohibitive (about $150 IIRC)
UPDATE:
So after some internet searching the Durometer rating of 60-65 for this product is similar to a rubber tire which should be perfect. PDF info here
I'm thinking with 50' of this stuff that I could draw up templates for the brackets and send off the instructions along with a long enough (6.5' for 2dr and 3dr civics from 92-95) chuck of rubber to make your own lip if you wanted.
I made the FiberEdge lip using a hacksaw, drill, 1/4" drill bit, 1/4" machine head screws and 1/4" nuts, and a vice and rubber mallet (for bending the brackets) and aluminum 1/8" thick 1" wide by 2' long flat stock bought from Home Depot.
The initial cost for the flat stock, bolts, and FiberEdge was $40, but that was for 16' of Fiberedge (enough to make two full lips) the Fiberedge was the expensive part, costing $33.
I'd like to know who else would be interested in getting the instructions and some rubber from me. PM would be best.
CivicVX.com<--- is down for now... PM me if you would like to help resurrect it.
