Old 03-06-2008, 04:31 PM   #13 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
diesel_john -
Originally Posted by diesel_john View Post
I have a digital A/F meter that shows me the magic 14.7 number. I got it because I wanted to "see" what an EFIE (02 sensor signal modifier) would do. But, when the EFIE is off, the A/F ratio is pretty much bouncing above and below 14.7, so it's not doing much, just like you said.
CarloSW2
How does this EFIE work? What does the circuit look like? I once played around with the O2 voltage by just adding 0.2 of a volt to the signal with a 3v battery and a simple $5 voltage divider circuit and it gave me a mile per gallon or more. Did not check the placebo effect. Newer ECU's are harder to fool.
diesel
Here's mine :
Eagle Research EFIE Online ...
http://www.gassavers.org/showthread.php?t=5036
I will repost this as a thread in ecomodder so you can see the pictures, but this will get you started for now.
CarloSW2
American Solar Energy Society
