Old 09-23-2009, 11:34 PM   #9 (permalink)
McTimson
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 36.46 mpg (US)
Does the jack have a separate release valve? If it does, make sure it's tightened all the way...
Or, just put a block on top of the jack, to give you the extra clearance. If you ever need to jack the car up higher than the jack allows, then the blocks work for that as well, just make sure you use the jack stands.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
