Old 09-24-2009, 11:35 AM   #21 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
I bet the panel will probably put out more than 36w... in perfect conditions (at noon, clean glass, clear sky, perfect orientation). But significantly less than that on average, since it will rarely be oriented toward the sun.
As a note: I did a simple test when I was playing with my solar powered boat this summer: just washing a light coat of pollen/dust off the glass improved power output by 5%.
Originally Posted by RobertSmalls View Post
Since the graph starts at 0:15, the way I read it, half an hour will give you +30°F. Not huge, but it's something.
Good eye, Robert. That was a mistake on my part in the graph! I didn't start the x axis at 0:00, but should have - the axis was off by 0:15 relative to the points on the curve. Fixed.
PS: 30 mins gives my setup +30F. YMMV! Results will definitely vary depending on engine/coolant mass, heater type etc.
PPS: I wouldn't worry much about mppt or what to do with your dump load. First make it work! Then make it better. :P
