In the end the fuel temperature had absolutely no impact on ignition timing, just the IAT had an impact.
The optimal setting is as much advance a you can get as long as you're still within spec. At idle max spec advance is 5 btdc. Whatever resistance you use will not give you more than 2 additional degrees.
