Old 09-24-2009, 02:35 PM   #10 (permalink)
solarguy
In 1983 I worked in the Texas oil field on a workover rig. That's like a mini oil drilling rig whose sole purpose is to rehabilitate old wells that are pooping out. There are a lot of tricks to increase production on older/depleted oil wells. One of the best, if you can afford to wait, is to stop pumping it for a decade. Most oil bearing formations are something like a sponge. As you pump out the oil, you deplete the local formation, and oil from further out slowly leaks/oozes/migrates/flows in to "refill" the pumped out area.
None of that requires the use of the abiotic oil theory to explain.
All other things being equal, the faster you pump a formation, the more "damage" you cause and the less you will be able to extract in the long run, all other things being equal, which they never are.
Finest regards,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
The Following User Says Thank You to solarguy For This Useful Post:
jkp1187 (09-30-2009)
