Thread: OBDuino Mega
Old 09-25-2009, 10:10 AM   #4 (permalink)
jonoxer
GPS, memory stick, and command line partly functional
It still needs a lot of work but tonight I partly integrated code for GPS, the memory stick, and a console interface into the OBDuino32K code.
As of right now I can connect to the OBDuino via a serial console and perform filesystem operations:
* List files on memory stick
* Delete OBDuino logfile
* Display OBDuino logfile
I can also activate and deactivate logging via the console, and a button on the device itself also toggles logging on / off.
While logging is on the main loop takes a GPS reading once for every pass through and writes it into a CSV file on the memory stick. I'm not logging any OBD data yet, that's the next step. Time to stop for the night and get some sleep now though.
For the curious:
jonoxer's obduino32KMega at master - GitHub
