Old 09-25-2009, 10:35 PM   #48 (permalink)
IsaacCarlson
eco....something or other
wood hauler - '91 F-250
90 day: 22.06 mpg (US)
3800 Sunfire - '02 Sunfire
New tires are weaker than broken in tires.
New tires should not be fully loaded or highly inflated because the steel bands in a new tire are all slightly different lengths and therefore some of them are bearing more tension than others. The steel bands in a used tire have been flexed and have stretched to the same length to bear forces evenly, making the tire MUCH stronger than a new tire. Inflate your tires to recommended specs for a few months and don't fully load them, to let the bands equalize, then increase your tire pressure, and payload.
I need two new tires this fall and will not be running my normal 50 lbs right off the bat.
Just my $.02 worth....
1991 F-250:
4.9L, Mazda 5 speed, 3.55 10.25" rear.
