Old 09-26-2009, 07:31 PM   #1218 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
I just installed the "Cougar 2" Open Source controller.
It was a little more complicated than the just swapping out the Curtis controller. That controller could take power from pack voltage. The open source controller requires wires to +12V & -12V, and a switch.
I installed a sub-fuse panel salvaged from an RV so I would have a new, dedicated 12V circuit, and than ran that to an illuminated switch inside the car.
That then turns the power on and off to the controller.
The car drives pretty well on the new controller. Acceleration is really smooth. It is GREATLY improved over the very first version of the controller. I had the throttle response on the Curtis controller cranked up. I had to be light on it to pull away from stops, but I could actually burn rubber with it too!
The Cougar isn't set to "burn rubber" mode, but you could stomp on the gas and get smooth, swift acceleration.
I think I would like to cram in two more batteries, for a 96V system. All of my other components can handle up to 108V nominal, and any more batteries would start to take up my cargo space!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
