Hmmm. Try a pm to Doax.
I've started using rivets for some of this type stuff, with fender washers like you see in the photos above wherever there's plastic. I can't tell for certain if those are rivets but they look like they might be. If fastening plastic to plastic I'd use a wide rivet like that on both sides, otherwise the rivet will just pull right through. I found that 5 mm. (3/16") rivets go well with some standard size washers I found.
Rivet gun is maybe $15 or so?? Rivets are not too much - a few dollars for a small box.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
