Thread: Belly Pan
Old 09-27-2009, 10:48 PM   #7 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Haha, I'm glad my simple grill block has inspired you.
Those are simply thumb screws with fender washers. They attach to another fender washer and wing nut on the back side. I wanted to keep it a tooless design in case I needed to remove them on the road. I picked them up at the local home improvement store I believe. Any good hardware store should have them too.
Thumb screw:
The screws on the bottom are just a fairly good sized phillips head screw and fender washer. I drilled holes in the bumper cover and let the screw do the tapping work. They hold great.
