I am going to take other peoples advice and try the rivet idea. Are there such things as removable rivets?
rivets are usually quite permanent, but aluminum pop rivets can be drilled out again without much damage to the surounding material.
for most underbody work in plastic or alluminum i use self tapping wood screws or sometimes nuts and bolts as these can always be undone with simple tools.
