Old 09-28-2009, 10:39 PM   #10 (permalink)
some_other_dave
Originally Posted by bgd73 View Post
fairbanks aK...driving a 1991 HF(?) what is an "HF"?
CRX HF, the "High Fuel efficiency" model. Rated at 50 freeway MPG stock, without a lean-burn engine or VTEC or anything more advanced than fuel injection.
The problem you (bgd73) are describing is "bad grounds". Could be a suspect in this case, but I would be more inclined to check the solder joints as was indicated earlier.
-soD
