Old 09-29-2009, 09:01 AM   #4 (permalink)
Old Mechanic
Red CBR - '011 CBR 250R
90 day: 74.21 mpg (US)
99 MAX - '99 Maxima GXE
90 day: 28.35 mpg (US)
Vulcan - '05 Vulcan 500 LTD
90 day: 56.4 mpg (US)
Use the manifold end of the booster hose. Bore a small hole right next to the fitting on the manifold so you can shorten the hose if you ever want to take it out.
Get one of those cone shaped adaptors that goes to many different size hoses for using the vacuum gauge.
Make the hole big enough to stick about 20% of the cone shaped adaptor in the hole in the brake booster hose. Shove the sucker in and if necessary use some adhesive to hold it in place.
Worked perfect in my Echo. The valve for the brake booster is in the booster itself.
regards
Mech
The Following User Says Thank You to Old Mechanic For This Useful Post:
UltraJosua (09-29-2009)
