If I had it to do over again I would have gone obd2 96-00 because of the maintenance. I think I may have had a problem that was accompanied by a check engine light once. If I could have all the time back that I've spent search for the reasons behind screwy idles or this or that misfire. I could have put it to good use. Plus obd2 cars are considerably cleaner. When I get back to Baltimore I want to put an HX engine in a 96-00 hatch. I should be comparable to the vx right.
