dcb, i posted up some save-tank code to the wiki Code Hacks page. If you only want the Save-tank, and not the Archive feature, it should be easy enough to weed it out.
(Also, i used the last "edit" on the page, and somehow it appended my hack onto the end of "Singletree's More Precision". Can you tell me how to fix it, so that ours are separate, and there is a new blank "edit" below mine?)
n/m. i got it. i needed the "== Hack ==" separator.
