Old 09-29-2009, 06:19 PM   #8 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
I disagree with all of the above posters, it is RARELY worthwhile to buy another vehicle to drive 8miles a day even at 12mpg.
So I will try to give you an answer,
First off, WHAT type of transmission does it have EXACTLY?
occasionally I am stuck with my v8 318 RAM Dodge Crewcab I use for craftshows and pulling trailers with a 4sp auto for going to work.
I have found that if I drive weird, kick the pedal 3x, take off firm and fairly hard then overshoot the speed limit a bit (still going about the same speed as 90% of the people around me or slower) and throw it in neutral and coast almost down to nothing and repeat. (works best timed with hills and required slow down points) I can move my in town MPGs up to approx 15-21mpg depending on how well I know the roads and how well I can time things.
And yes that is with an auto which is the most useless transmission to have.
A good note is that is the same FE my buick gets in town unless I have lots of opportunities to coast and drive faster.
If you have a manual, test your vehicle with engine off on a straight flat vacant section of road to see how much you can use the brakes and steering. I am not afraid of using EOC when I will have to come to a stop on a straight section of road. Use common sense and get to know your vehicle, and A manual transmission and engine off accessory position will be your friend. Just keep a hand ready to clutch on if need be.
Dodges are quirky and a scanguage would help you determine how to get better FE out of your undersized 6 banger.
Depending on how serious you are you might take this as a challenge to figure out how the dodge 6 banger works best.
Good Luck
Ryan
Originally Posted by caffinefiend View Post
I live in the east bay of the San Francisco bay area. My nightly commute is only 8 miles round trip, So, I tried hydrox but got nowher with that though I was producing lots and lots of browns gas. I'm sure there's some posts here with ideas to improve my lousy mpg. suggestions of where to look??
Thanks, caffinefiend
