Old 09-29-2009, 06:07 PM   #13 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Originally Posted by seeodywhy View Post
If I had it to do over again I would have gone obd2 96-00 because of the maintenance. I think I may have had a problem that was accompanied by a check engine light once. If I could have all the time back that I've spent search for the reasons behind screwy idles or this or that misfire. I could have put it to good use. Plus obd2 cars are considerably cleaner. When I get back to Baltimore I want to put an HX engine in a 96-00 hatch. I should be comparable to the vx right.
When you say that the '96 + cars were considerably cleaner, you are talking about the emissions right ?
I think my '93 is rated as a Tier II and the '96 + cars were rated as an LEV.
That's a good reason to not go for the older model, yet with the older car getting higher MPG, where do the two cars match each other in emissions output ?
Regarding the older car not being able to use a ScanGuage ( Not OBD2 ) , I use something very similar called a SuperMID. Other users on this site with the same car use the open source MPGuinio ( did I spell that right guys ?)
