Old 10-01-2009, 02:01 AM   #40 (permalink)
pgfpro
pgfpro's Avatar
Originally Posted by naturalextraction View Post
Sounds about right. I'm impressed with the operating parameters of that system. It seems as though you've managed to develop some modifications of your own in order to get some of the read out and results. Allways continue to devise methods that provide as much accuracy as possible! That separates you from thousands of those with unsubstantiated claims and or ridiculous means in which to quantify or "prove" their results. My Kudos to you and my I encourage you to continue to develop accuracy in your testing.
Stay in touch. I'd like to know more about your testing and experiments.
Our testing at the labs got moved till Feb of 2010. I have much data to compile on our system and I was looking forward to testing. Now I guess next year.
Thanks again you have been most helpfull.
That sucks you have to wait until next year.
One of the things you mention was that the turbo is doing a lot more then I thought it was as for FE and controlling combustion. This is something I didn't think about and did some ABA testing to confirm it. Lets just say without the turbo my engine would eventually be burned down.LOL
I have been keeping a ton of logs and information as I make changes. I will eventually show this as I put it all together. Right now I'm trying to get as many miles in as I can because the winters up here are tough and snow is just around the corner. Plus one thing that really frustrates me is how my mileage is so temperature sensitive.
One more thing I want to do is let someone borrow the car I can trust and have them drive it a couple thousand miles and keep track of the fuel mileage. This will take me... the owner out of the equation.
I'm going to do a write up on all my mods this winter with a ton of pics.
I ran into this to be honest by mistake.
It all started with a Pat Musi BBC 565CI nitrous motor. Its a trick the Pro Mod guys did to run a leaner nitrous to fuel ratio. They did this because when you start running multiple systems fuel starts to puddle in the intake runners and make the engine go lean.
I then applied it to my Honda motor that was turbo charged with nitrous. One day coming back from the track I noticed that the wide band gauge was reading extremely lean but the engine ran fine. I later found out I had a clog fuel pump filter. So I fix that and decided to see if it would run that lean again or was I just imaging it. So I took a ton of fuel out of it with my Haltech system and it ran great. Then it got my curiosity and it was time to check the fuel mileage and I was amazed.
Anyway enough rambling.
