Old 10-01-2009, 04:25 PM   #1 (permalink)
Sebastian
Switched power source
First please excuse my english. I will try my best
I'm going to mount a MPGuino to my motorcycle over the winter. But I won't leave it on it permanently if not necessary. I read it needs a non switched power source, so what will happen if I unplug it between the rides, lost data? (I also know I should wait 20s for reconect, no problem with that)
If somebody is interested: I have to rewrite the code so it outputs "european metric" units (L/100km). I hope I'm able to do that based on the 0.75 metric version (my programming skills are limited). Hints are welcome and of corse I will publish the result here if it works!
Edit: Should I expect any problems due to high rpm on a motorcycle? Redline is around 11.000rpm, and it injects on every top death center (like 2 stroke engine) cause it hase no camshaft sensor. So MPGuido may meter up to 22.000rpm..
