Old 10-02-2009, 09:29 AM   #11 (permalink)
tjts1
Not unless you can put a smaller engine into your vehicle.
A lot of cars already have a small enough engine that they can gain FE by simply adding a turbo. No down sizing required. Take a look an LPT (low pressure turbo) volvo. It will climb steep. Hills at low RPM (1000-1500) in third gear at low speed all day and return better FE than the NA version in the same situation.
