Old 10-02-2009, 05:31 PM   #20 (permalink)
damo
Alfie - '03 156 Veloce
90 day: 34 mpg (US)
Smarty - '05 Roadster Coupe 80
90 day: 44.05 mpg (US)
Alfena - '05 147 JTD 8v Turismo
90 day: 40.62 mpg (US)
Originally Posted by andylaurence View Post
I also checked the prices of steel wheels and wheel trims for the ForTwo. 3.5"x15" wheels are ~£31+VAT and 4"x15" are ~£35+VAT. I can get some clip-in wheel trims for £25 and a few minutes with a hacksaw, a sheet of ABS, a craft knife and some epoxy should get me some aero wheels.
I was looking at the offset differences in switching wheels.
Using the fq101 wheel info FQ101 : Taking Modification to the Next Level
and then an offset calculator Wheel Offset Calculator
It looks like if you changes to 4 inch rims on the front, the rims would be recessed by 16mm against your spinlines. Rears would be in by 25mm. I think the smart wheel trims look good (and aerodynamic) but are expensive at £25 each.
The wiper arms were difficult to take off, I had to get a wiper arm puller from e-bay. Don't think it will ever be worth £10!
Must get some pics of my grill block for you.
Also I was thinking about the diffuser you mentioned. I think it would make the aero worse. The vacuum it creates would only add more drag. The Chevy Volt aero video convinced me of this. On the other hand, i'm not sure if i'm prepared to add straight edges to the back of the car to help the airflow detach from the back of the car cleanly.
