Old 10-03-2009, 01:37 PM   #44 (permalink)
Xringer
Old Retired R&D Dude
Transporter - '09 Escape XLS
East side of house, between house and garage (10' away).
I moved* the water tap down to the right about four feet, and will use the left-over hole
to feed out the 230VAC to the cut-off box. (provided with the kit).
*Used 1/2" SharkBite 90deg Elbows & PEX pipe.
The line-set will feed up (on the outside of the wall) to the 3 inch hole,
where it will connect into the indoor unit.
The main units look a bit like this.. This picture is not to scale..
Cheers,
Rich
